Autor Tema: Tiro los Guante con el DMXPACK!!!!!  (Leído 6963 veces)
« en: 24 de Noviembre de 2007, 08:01:25 »
Despues de largas luchas con el codigo sin resultados positivo tiros los Guante :x :x :x
« Última modificación: 02 de Diciembre de 2007, 14:13:51 por stk500 »
Re: DMXPACK solo funciona analogo in
« Respuesta #1 en: 24 de Noviembre de 2007, 08:04:54 »
Aqui la 2da Parte
      ORG     Start_Vector       ; processor reset vector
      nop                        ; Included for ICD
      clrf    PCLATH               ; ensure page bits are cleared
        goto    Start                 ; go to beginning of program
      ORG     Interrupt_Vector      ; interrupt vector location
      MOVWF   Int_W                ; Save PIC state
        SWAPF   STATUS,W
        CLRF    STATUS
        MOVWF   Int_Status
        MOVF    PCLATH,W
        MOVWF   Int_PCLath
        CLRF    PCLATH
        BCF     STATUS,IRP
        MOVF    FSR,W
        MOVWF   Int_FSR
IH_Interrupt_Poll
      btfsc    INTCON,T0IF      ; Test for timer0 interupt
      goto    IH_Timer0      ; Yes, Goto timer0 Handler
      btfsc    PIR1,RCIF      ; USART Interupt Pending ?
      goto   IH_Check_USART   ; Yes, Goto Usart handler
      btfsc    INTCON,INTF      ; Test for RB0 Interupt
      goto    IH_RB0
      btfsc   PIR1,TMR1IF      ; Timer 1 interupt ??
      goto   IH_Timer1
IH_Exit  movf    Int_FSR,W      ; Restore PIC state
         movwf   FSR
         movf    Int_PCLath,W
         movwf   PCLATH
         swapf   Int_Status,W
         movwf   STATUS
         swapf   Int_W,F
         swapf   Int_W,W
         retfie               ; Return from interrupt
IH_Timer0
      movf    countervalue,w
      movwf    TMR0         ; Reload counter0
                        ; Channel 1
      decf    IH_channel1cnt,f; decrease channel 1 count
      btfsc    STATUS,Z      ; if zero then set output
      bcf    channel1op      ; set output
                        ; Channel 2
      decf    IH_channel2cnt,f; decrease channel 2 count
      bcf    channel2op      ; set output
                        ; Channel 3
      decf    IH_channel3cnt,f; decrease channel 3 count
      bcf    channel3op      ; set output
                        ; Channel 4
      decf    IH_channel4cnt,f; decrease channel 4 count
      bcf    channel4op      ; set output
      incf    IH_position_count,f   ; increse pulse count
      bcf    INTCON,T0IF      ; Clear interupt
      goto    IH_Interrupt_Poll
IH_RB0   bsf    STATUS,RP0      ; change to bank 1
      btfsc    OPTION_REG,INTEDG   ; Test which edge of zerocross looking for
      goto    IH_RB0_End      ; 1 = rising edge
IH_RB0_Start
      bsf    OPTION_REG,INTEDG   ; set to look for Rising Edge
      bcf    OPTION_REG,T0CS      ; Enable timer 0
      bcf    STATUS,RP0         ; move back to bank 0
      bcf    INTCON,INTF         ; Clear interupt flag
      clrf    IH_position_count   ; clear pulse count
      bsf    INTCON,T0IF         ; Create timer Interupt
      clrf   TMR1L            ; Clear Timer1
      clrf   TMR1H
      bcf      flag,mains_fail      ; and flags....
      btfsc    PIR1,RCIF         ; Is USART interrupt Pending ?
      goto    IH_Check_USART      ; Yes, Do USART rec bit before going to handler.
      incfsz    IH_Timer_Count,f   ; No, Increase No DMX Data Count
      goto    IH_Interrupt_Poll   ; If NOT Zero then goto handler
   if basic == 1
      bcf    Data_Rec_LED      ; If Zero, Clear DMX data recieve LED
      bcf      Data_Error_LED      ; And the DMX Error LED
   endif
      bcf      flag,DMX_Data      ; Clear DMX recieve flag
      clrf   Iflag            ; Clear any DMX data being recieved
IH_RB0_End
      bsf    OPTION_REG,T0CS      ; Disable Timer 0
      bcf    INTCON,INTF         ; Clear Interupt flag
      bcf    OPTION_REG,INTEDG   ; Set RB0 Interupt to falling edge
      bcf    STATUS,RP0         ; change to bank 0
      movlw   .254
      movwf    PORTB            ; clear ouputs
      movf    channel1update,w   ; reload channel count
      movwf    IH_channel1cnt
      movf    channel2update,w   ; reload channel count
      movwf    IH_channel2cnt
      movf    channel3update,w   ; reload channel count
      movwf    IH_channel3cnt
      movf    channel4update,w   ; reload channel count
      movwf    IH_channel4cnt
      movf    IH_position_count,w   ; save pulse count
      movwf    position_count
      bsf    flag,phase_done
      decfsz   IH_Long_Count,f      ; Decrease Long Count
      bsf      flag,longcount      ; set long count
IH_Check_USART
         bcf    PIR1,RCIF         ; Clear Interupt flag
      ;bsf   Data_Rec_LED      ; Set DMX Data LED
IH_Check_HW_Overrun
       btfsc   RCSTA,OERR      ; Has a HW overrun occurred ?
        goto    IH_HW_Overrun   ; Yes, do a HW reset
IH_Check_9th_bit
      clrf   IH_Timer_Count      ; Clear Timer count
      btfss    RCSTA,RX9D         ; Dose 9th Bit of data = 1, eg Break
      goto    IH_Wait_Break      ; Yes, start receiving again
IH_Check_SW_Overrun
       btfsc   RCSTA,FERR            ; Has a framing error occurred ?
        goto    IH_SW_Overrun      ; Yes, do a Usart reset
IH_Test_Flags
      btfsc    Iflag,Valid_Channel   ; Test to see if receiving valid channels
      goto   IH_Valid_Channel   ; Yes, get next channel
      btfsc   Iflag,Start_Detected   ; Test to see it start byte has arrived
      goto   IH_Wait_Channel      ; Yes, Check Channel counts
      btfsc   Iflag,Break_Detected   ; Test to see if break has arrived
      goto   IH_Wait_Start      ; Yes, wait for start byte
IH_Wait_Break
      clrf   Iflag            ; Clear all interupt flags
      movf   RCREG,w            ; Move recieved data in to w
      btfsc   RCSTA,RX9D         ; Test if break has arrived
      goto   IH_Interrupt_Poll   ; No,  Break not detected
      btfsc   STATUS,Z         ; Yes, Dose detected break =0 ?
      bsf    Iflag,Break_Detected   ; Yes, set flag to indicate break arrived
IH_Wait_Start
      clrf   IH_Channels_Recieved   ; Clear number of channels recieved
      clrf   IH_Channel_Count_L      ; Clear Low channel count
      clrf   IH_Channel_Count_H      ; Clear High channel count
      bsf      Iflag,Start_Detected   ; Set flag to indicate Start Byte arrived
      movf   RCREG,w               ; Check start code = 0
      btfss   STATUS,Z            ;
      clrf   Iflag               ; if No then clear flags and wait for next break
IH_Wait_Channel
      movf   RCREG,w               ; Store Recieved value in temp
      movwf   IH_Temp
      incf   IH_Channel_Count_L,f   ; Increase channel count
      btfsc   STATUS,Z            ; for both Low and High bytes
      incf   IH_Channel_Count_H,f   ;
      movf   IH_Channel_Count_H,w   ; Compare the high byte of channel count to
      xorwf   DMX_Start_Addr_H,w      ; DMX start address
      btfss   STATUS,Z            ; If Not equal then exit
      movf   IH_Channel_Count_L,w   ; Compare the low byte of channel count to
      xorwf   DMX_Start_Addr_L,w      ; DMX Start address
      btfss   STATUS,Z            ; if not equal then exit
      bsf      Iflag,Valid_Channel      ; if address equal then set valid channels
      movf   IH_Temp,w
      movwf   Channel_Values         ; Store value in first channel
      incf   IH_Channels_Recieved,f   ; and increase count
IH_Valid_Channel
      movlw   Channel_Values         ; Load address of memory block
      addwf   IH_Channels_Recieved,w   ; add channel offset
      movwf   FSR                  ; and move in to FSR
      movf   RCREG,w               ; Store result in the
      movwf   INDF               ; channel position in memory
      movf   IH_Channels_Recieved,w   ;
      incf   IH_Channels_Recieved,f   ; Increase count (Note No effect on w !)
      xorwf   Channels,w            ; Check if all channels recieved
      btfss   STATUS,Z            ;
      goto   IH_Interrupt_Poll      ; No, then return to interupt poll
      clrf   Iflag               ; Yes, Clear flags and wait for break
   if basic == 1
   endif
      bsf      flag,DMX_Data         ; Set DMX Data recieve flag
      goto    IH_Interrupt_Poll      ; exit back to Handler
IH_HW_Overrun
       bcf      RCSTA,CREN               ; Reset UART
        bsf     RCSTA,CREN               ; receive logic
        bsf     flag,dmx_error           ; Turn on hardware overrun LED
   if basic == 1
      bsf      Data_Error_LED         ; Turn on DMX Error led
   endif
      goto    IH_Check_9th_bit
IH_SW_Overrun
       bcf     RCSTA,CREN               ; reset UART
      bsf      flag,dmx_error         ; Turn on software Overrun Led
   if basic == 1
   endif
      goto    IH_Test_Flags
IH_Timer1                  ; Mains Phase Fail
      bcf      PIR1,TMR1IF      ; Clear interupt flag
      bsf      flag,mains_fail   ; Set Mains Fail Flag
      movlw   .254
      goto   IH_Exit
seg_table               ; Table for 7 Segment display
      addwf   PCL,f         ; Place before possible programme
      retlw .129    ; 0
      retlw .243    ; 1
      retlw .73    ; 2
      retlw .97    ; 3
      retlw .51    ; 4      ; Web Site Version
      retlw .37    ; 5
      retlw .7    ; 6
      retlw .241    ; 7
      retlw .1    ; 8
      retlw .49    ; 9
      retlw .67    ; d
      retlw .17    ; A
      retlw .25    ; P
      retlw .13    ; E
      retlw .79    ; c
      retlw .23    ; h
      retlw .255    ; <OFF>
Start   clrf    PORTA           ; \
        movlw   .254            ;  Clear ports
        movwf   PORTB         ;
      clrf    PORTC           ; /
      clrf    flag         ; Clear flag register
      clrf   flag2
      clrf    Iflag         ; Clear Interupt flag
      clrf   dflag         ; Clear Display Flags
      clrf   DMX_Start_Addr_L; Clear DMX Address
      clrf   DMX_Start_Addr_H;
      clrf   Current_Preset
      clrf   olddisplayvalue
      clrf   STATUS         ; Clear status
      bsf      STATUS,RP0      ; Set up port I/O directions
        movlw    B'11111111'      ; 1 = Input    0 = Output
        movwf    TRISA         ; Make PORTA all input
        movlw    B'00000001'
        movwf    TRISB         ; Make PORTB all Output expect PB0
        movlw    B'000000000'   ; Set AN0 - AN4 As analogue inputs left justified
        movwf    ADCON1
      movlw    B'11001000'      ; set up options - Timer0 from instruction cycle clock with
      movwf    OPTION_REG      ; no prescaler
Get_DMX_Address
      movlw   B'10001111'      ; Set Up Switch directions
      movwf   TRISC
      bcf      STATUS,RP0      ; Go back to bank 0
      nop
      movlw   B'00010000'      ; Enable first bank of switches
      movwf   PORTC
      call   Delay         ; Go for a little delay
      movf   PORTC,w         ; Read Port C
      andlw   B'00001111'      ; Mask un required bits
      movwf   DMX_Start_Addr_L; Store in addrees Low
      movlw   B'00100000'      ; Get next bank of switches
      movwf   PORTC
      call   Delay
      swapf   PORTC,w         ; Read switches and swap nibbles
      andlw   B'11110000'      ; Mask undesirables
      iorwf   DMX_Start_Addr_L,f   ; Store Higher nibble
      movlw   B'01000000'      ; Get final bank of switches
      movwf   PORTC
      call   Delay
      movf   PORTC,w         ; get switches
      andlw   B'00001111'      ; mask narstry bits
      movwf   process_temp
      andlw   B'00001110'      ; store other switch settings in flags.
      movwf   flag
      btfsc   process_temp,0   ; look for high address bit.
      incf   DMX_Start_Addr_H,f   ; and set if required
      clrf   PORTC         ; Clear Port C
      movf   DMX_Start_Addr_H,w
      movwf   NumH         ; Load BIN -> BCD Converter
      movf   DMX_Start_Addr_L,w
      movwf   NumL
      call    bin2dec999fast   ; Get BCD version of DMX Start Address
   if basic == 1            ; ONLY DO FOR BASIC PACK
      bcf    Data_Rec_LED   ; Turn off Data Recieve LED
      bcf      Data_Error_LED   ; Turn Off DMX Error LED
   endif
store_Number_channels
      movlw   Number_Of_Channels
      movwf   Channels   ; Load Number of channels to recieve and store
; Initialize UART
      bsf     STATUS,RP0
        movlw   Baud_Rate_Constant
        movwf   SPBRG
        bsf     TXSTA,BRGH
        bcf     TXSTA,SYNC
        bsf     PIE1,RCIE
        bcf     STATUS,RP0
        bsf     RCSTA,RX9
        bsf     RCSTA,CREN
        bsf     RCSTA,SPEN
      movlw    B'10000001'      ; Switch on the ADC channel RA0 20Mhz crystal
      movwf    ADCON0
      movlw    Timer0_cnt
      movwf    countervalue   ; load counter reload variable
      movwf    TMR0         ; Load counter
      bsf    OPTION_REG,T0CS   ; Disable timer 0
      movlw   B'00110001'      ; Setup Timer1
      movwf   T1CON         ; 1:8 Prescale - internal osc...
      clrf   TMR1H
      bsf      STATUS,RP0      ; Bank 1
      bsf      PIE1,TMR1IE      ; Enable Timer 1 Interupt
      bcf      STATUS,RP0
; Interrupts
      clrf    INTCON
      bsf      INTCON,PEIE
      bsf    INTCON,INTE      ; Enable RB0 Interupt
      bsf      INTCON,T0IE      ; Enable Timer0 Interrupts
      bsf    INTCON,GIE      ; Enable global interrupts
Main
      btfsc   flag,mains_fail      ; Is Mains Ok ??????
      call   D_Mains_Fail      ; No,
      btfsc    flag,DMX_Data      ; Is DMX Data being recieved ?
      goto    load_update_reg      ; Yes, then just updata channels
   if basic == 0               ; ONLY DO FOR Normal PACK
      btfsc   flag,presetmode      ; Is preset mode selected ???   ***
      goto   preset_mode         ; Yes,            ***
   endif
Get_Analogue_Values               ; No, get Analogue values
      movlw    B'10000001'         ; select Channel 1 in A2D
      movwf    ADCON0
      call    Delay
      bsf    ADCON0,GO         ; start ADC conversion
      nop
      nop
wait1   btfsc    ADCON0,GO         ; Loop till conversion complete
      goto    wait1
      movf    ADRESH,w         ; get and
      movwf    Channel_Values      ; store channel 1
      nop
      movlw    B'10001001'         ; select Channel 2 in A2D
      movwf    ADCON0
      call    Delay
      nop
      nop
wait2   btfsc    ADCON0,GO         ; Loop till conversion complete
      goto    wait2
      movwf    (Channel_Values+1)   ; store channel 2
      nop
      movlw    B'10010001'         ; select Channel 3 in A2D
      movwf    ADCON0
      call   Delay
      nop
      nop
wait3   btfsc    ADCON0,GO         ; Loop till conversion complete
      goto    wait3
      movwf    (Channel_Values+2)   ; store channel 3
      nop
      movlw    B'10011001'         ; select Channel 4 in A2D
      movwf    ADCON0
      call    Delay
      nop
      nop
wait4   btfsc    ADCON0,GO         ; Loop till conversion complete
      goto    wait4
      movwf    (Channel_Values+3)   ; store channel 4
load_update_reg
      movf    Channel_Values,w   ; copy and invert value from Channel 1
      call   process_curve      ; Get value form curve
      movwf    channel1update
      movf    (Channel_Values+1),w; copy and invert value from Channel 2
      call   process_curve      ; Get value from curve
      movwf    channel2update
      movf    (Channel_Values+2),w; copy and invert value from Channel 3
      call   process_curve      ; Get Value from curve
      movwf    channel3update
      movf    (Channel_Values+3),w; copy and invert value from Channel 4
      movwf    channel4update
      clrf   PCLATH            ; Clear PCLATH from scurve.
      btfss    flag,phase_done      ; is phase complete ??
      goto    Main            ; No,
      call    find_countervalue   ; Yes, update counter value
      call    display            ; Do display                ***
   endif
      goto    Main
« Respuesta #2 en: 24 de Noviembre de 2007, 08:08:55 »
aqui la 3ra Parte
; *      Preset Mode            *
preset_mode
      bsf      STATUS,RP0         ; Move to bank 1
      movlw   B'00000110'         ; Set port A as digital inputs.
      movwf   ADCON1
      bcf      STATUS,RP0         ; return to bank 0
      nop                     ; delay to reset porta
      nop
      movf   PORTA,w            ; copy port A in to shadowa
      movwf   shadowa
      xorwf   oldporta,w         ; look for changes
      andwf   shadowa,w         ; look for rising edge only.
      movwf   oldporta         ; and store in oldporta !
      btfsc   oldporta,4
      call   channel5
      btfsc   oldporta,5
      call    channel6
      movf   shadowa,w
      movwf   oldporta
      btfss   flag2,savepreset   ; if save preset active then
      bsf      STATUS,RP0         ; move to bank 1
      movlw   B'00000010'         ; set PORTA back to Analogue
      movwf   ADCON1
      nop                     ; Delay to reset
      nop
      goto   Get_Analogue_Values ; display analogue values
channel5
      btfsc   flag2,savepreset   ; Is save preset in progress
      goto   save_to_ee         ; Yes,
      btfsc   shadowa,5         ; No, both buttons pressed ??
      goto   save_preset         ; Yes,
      movf   Current_Preset,w   ; No, Load Current Preset in to Status register
      movlw   Max_Preset+1      ; set up w with new value
      btfsc   STATUS,Z         ; current preset = 0 ??
      movwf   Current_Preset      ; Yes, reload with maxium value then
      decf   Current_Preset,f   ; No, decrease current preset
      goto   update_preset
channel6
      btfsc   shadowa,4         ; No, Both buttons presed ?
      incf    Current_Preset,f   ; No, Increse present preset
      sublw   Max_Preset         ; subtract max preset from preset
      btfsc   STATUS,C         ; To Large ??
      goto   update_preset
      clrf   Current_Preset
update_preset
      movf   Current_Preset,w   ; Move current preset to ee_address (in all Mem)
      movwf   ee_address
      rlf      ee_address,f         ; * 4.
      rlf      ee_address,f
      call   ee_read            ; Get channel 1 value
      movwf   (Channel_Values)
      incf   ee_address,f
      call   ee_read            ; Get channel 2 value
      incf   ee_address,f
      call   ee_read            ; Get channel 3 Value
      incf   ee_address,f
      call   ee_read            ; Get channel 4 Value
      return
save_preset
      bsf      flag2,savepreset         ; Set save preset mode
      return
save_to_ee
      btfss   shadowa,4         ; Check CH5 is selected.
      return                  ; No,
      btfss   shadowa,5         ; Check CH6 is selected
      return                  ; No,
      movf   Current_Preset,w   ; Yes, Both channels
      movwf   ee_address         ; set up EEaddress with current preset
      rlf      ee_address,f
      movf   (Channel_Values),w
      movwf   ee_data
      call   ee_write         ; save Channel 1 Value
      incf   ee_address,f
      movwf   ee_data
      call   ee_write         ; save Channel 2 Value
      incf    ee_address,f
      movwf   ee_data
      call    ee_write         ; Save Channel 3 Value
      incf   ee_address,f
      movwf   ee_data
      call   ee_write         ; save Channel 4 Value
      bcf      flag2,savepreset      ; Clear flag
      clrf   oldporta         ; to prevent rerunning
      return
; *                  Display Errors                    *
; *   Input - flags                Output - Nothing          *
D_Mains_Fail
   if basic == 1
      bsf    Data_Rec_LED      ; Switch On Both LEDs
   else
      movlw   .15               ; Display a F for Mains Fail
      call   seven_seg
   endif
      bcf      INTCON,T0IE         ; Disable Timer0 Interrupts
D_No_Mains_Loop                  ; No Mains Loop........
      goto   D_No_Mains_Loop
      call   Delay
      return
; *        Display Routien                      *
; * Input - Control flags     output - Nothing  *
display
      btfsc   flag,DMX_Data      ; Dmx Currently ??
      goto   dmx_display         ; Yes,
      movlw   B'11110000'         ; No, Clear dmx part of dflag
      andwf   dflag,f
      bcf      flag,dmx_error      ; clear dmx error flag
      btfsc   flag,presetmode      ; In Preset Mode Currently
      goto   preset_display      ; Yes,
analogue_display            ; No,
      movlw   .11         ; Display A
      goto    seven_seg
dmx_display
      bcf      dflag,preset_intro
      btfsc   flag,dmx_error      ; Dmx error recieved ??
      goto   display_error      ; Yes,
      btfsc   dflag,dmx_lsb      ; Displaying LSB ??
      goto   display_d         ; Yes,
      btfsc   dflag,dmx_csb      ; Displaying CSB ??
      goto    display_lsb         ; Yes,
      btfsc   dflag,dmx_msb      ; Displaying MSB ??
      goto   display_csb         ; Yes,
      btfsc   dflag,dmx_recieve   ; Displaying New d ??
      goto   display_msb         ; Yes,
      clrf   IH_Long_Count
      bcf      flag,longcount      ; Clear and reset Long Count
      bsf      dflag,dmx_recieve
      movlw   .10               ; display d.
      goto   seven_seg
display_msb
      btfss   flag,longcount      ; Has long count finished ??
      return                  ; No,
      clrf   IH_Long_Count      ; Yes, reset long count
      bcf      flag,longcount
      bsf      dflag,dmx_msb      ; set display flag
      movf   dmx_hund,w         ; and display
      goto    seven_seg
display_csb
      return                  ; No,
      bcf      flag,longcount
      bsf      dflag,dmx_csb      ; set display flag
      movf   dmx_ten,w         ; and display
      goto    seven_seg
display_lsb
      return                  ; No,
      bcf      flag,longcount
      bsf      dflag,dmx_lsb      ; set display flag
      movf   dmx_one,w         ; and display
      goto    seven_seg
display_d
      return
      movlw   .10               ; Value for d
      goto   seven_seg         ; And display
display_error   movlw   .13         ; Value for E
      goto   seven_seg         ; and display
preset_display
      btfsc   flag2,savepreset   ; Preset Save taking Place ??
      goto    display_save      ; Yes,
      btfsc   dflag,preset_intro   ; Done Intro Yet ??
      goto   display_current_preset   ; Yes,
display_p
      bsf      dflag,preset_intro   ;
      clrf   IH_Long_Count      ; clear and reset long count.
      bcf      flag,longcount
      movlw   .12               ; Value for p
      goto   seven_seg
      btfss   flag,longcount      ; Wait for long count
      return
      movf   Current_Preset,w   ; display current preset (0 - 9)
      goto    seven_seg
display_save   movlw   .14         ; Save chacture = c
      goto   seven_seg
; *          7 Segment Display Drive      *
; *   Input - w       Output = Nothing    *
seven_seg
      movwf   displayvalue
      xorwf   olddisplayvalue,w   ; Has display value changed ?
      btfsc   STATUS,Z      ;
      return            ; No,
                  ; Yes, Display neww value
      movf   displayvalue,w
      movwf   olddisplayvalue      ; Update old display value
      call    seg_table
      movwf   displayvalue
      movlw   .8
      movwf   display_count
seven_loop
      bcf      display_clk      ; End of clock pulse
      nop
      btfsc   displayvalue,0      ; Set next data output
      bsf      display_data
      btfss   displayvalue,0
      bcf      display_data
      nop
      nop
      rrf      displayvalue,f      ; set up next data value
      nop
      bsf      display_clk      ; start of clock pulse
      nop
      nop
      decfsz   display_count,f      ; all data done yet ??
      goto    seven_loop
      return
; *        Find counter value required        *
; * Input - position_count  output - countervalue *
find_countervalue            ; find amount left on counter and adjust counter
                        ; value to make counter = 255 at end.
      bcf    flag,phase_done   ; do this only after new mains cycle.
      btfss    position_count,7; if position count >128 then decrese count
      goto    lower_count      ; else increase count
higher_count   movf    position_count,w
      sublw    .255         ; Sutract 254 from positioncount
      btfsc    STATUS,C      ; if < 0 then
      incf    countervalue,f   ; increase count
      return
lower_count   movf    position_count,w
      sublw    .1            ; Sutract 2 from positioncount
      btfss    STATUS,C      ; if > 0 then
      decf    countervalue,f   ; decrease count
      return
; *      EEREAD                                 *
; * ee_address = Address in EEPROM  w = data read      *
ee_read
      bsf      STATUS,RP1      ; Move to bank 2
      movf   ee_address,w
      movwf   EEADR         ; Store eeaddress in correct location
      bsf    STATUS,RP0      ; Go to Bank 3
      bcf      EECON1,EEPGD   ; Point to Data Memory
      bsf    EECON1,RD      ; Start EEprom read cycle
      bcf    STATUS,RP0      ; Back to bank 2
      movf    EEDATA,w
      bcf    STATUS,RP1      ; Bank to bank 0
      return
; *              EEWRITE                               *
; *  EEadr = Address in EEPROM eedata = data to write  *
ee_write
      bcf      PIR2,EEIF      ; clear EE interupt flag
      bcf      STATUS,RP0      ;
      movf   ee_address,w
      movwf   EEADR         ; Save eeaddress
      movf   ee_data,w
      movwf    EEDATA         ; save eedata
      bsf    STATUS,RP0      ; Move to bank 3
      bcf      INTCON,GIE      ; Disable interupts
      bcf      EECON1,EEPGD   ; Access Data Memory
      bsf    EECON1,WREN      ; put WREN
      movlw    H'55'
      movwf    EECON2
      movlw   H'AA'
      movwf    EECON2
      bsf    EECON1,WR      ; write cycle started
      bcf      STATUS,RP0      ; goto Bank 0
      bcf      STATUS,RP1
wr1      clrwdt
      btfss    PIR2,EEIF      ; wait for EE write interupt flag
      goto    wr1            ; write cycle wait
      bsf      INTCON,GIE      ; Enable all interupts
      return
; * Fast binary to decimal conversion (0..999)   *
; *  Input: NumH:NumL            *
; * Output Hund:Tens_Ones (packed BCD)      *
; * Size: 59 instructions         *
; * Execution time (with return): 60      *
; * 8-July-2000 by Nikolai Golovchenko      *
; * Based on 8bit BIN2BCD of Scott Dattalo   *
bin2dec999fast
        swapf   NumL,w      ;Add the upper and lower nibbles
        addwf   NumL,w      ;to get the one's digit
        andlw   0x0F
        skpndc            ;Go through a binary to bcd
        addlw   0x16      ;conversion for just the one's
        skpndc            ;digit
        addlw   0x06
        addlw   0x06
        skpdc
        addlw   -0x06
        btfsc   NumL,4      ;bit 4 is a special case
        addlw   0x16 - 1 + 0x6
        skpdc
        addlw   -0x06      ;now adjust the ten's digit
        btfsc   NumL,5      ;2^5 = 32, so add 3 to the ten's
        addlw   0x30      ;digit if bit 5 is set
        btfsc   NumL,6      ;2^6 = 64, so add 6
        addlw   0x60      ;if bit 6 is set
      btfsc   NumL,7      ;2^7 = 128, so add 2 (the ten's
      addlw   0x20      ;digit) if bit 7 is set
      addlw   0x60      ;convert the ten's digit to bcd
      clrf   Hund
      rlf      Hund,f      ;if there's a carry, then the input
      btfss   Hund,0      ;was greater than 99.
      addlw   -0x60
      movwf   Tens_Ones
      movlw   0x66      ;2^8 = 256, so add 0x56 to Tens_Ones
      btfsc   NumH,0
      movlw   0x56 + 0x66   ;add 0x66 for decimal adjust
      addwf   Tens_Ones,f
      skpnc
      incf   Hund,f
      clrw
      skpc
      iorlw   0x60
      skpdc
      iorlw   0x06
      subwf   Tens_Ones,f
      movlw   0x66      ;2^9 = 512, so add 0x12 to Tens_Ones
      btfsc   NumH,1
      movlw   0x12 + 0x66
      addwf   Tens_Ones,f
      skpnc
      incf   Hund,f
      clrw
      skpc
      iorlw   0x60
      skpdc
      iorlw   0x06
      subwf   Tens_Ones,f
      btfsc   NumL,7      ;finish with hundreds
      incf   Hund,f
      movlw   2
      btfsc   NumH,0
      addwf   Hund,f
      movlw   5
      btfsc   NumH,1
      addwf   Hund,f
split
      movf   Hund,w
      movwf   dmx_hund
      movf    Tens_Ones,w
      andlw    0Fh
      movwf   dmx_one
      swapf   Tens_Ones,w
      andlw   0Fh
      movwf   dmx_ten
      return
; *      Delay Loop             *
; *     No Input      No Output      *
Delay
      movlw   Delay_Value
      movwf   Delay_Count
Delay_Loop
      decfsz    Delay_Count,f
      goto    Delay_Loop
      return
; *             Process Required Curve         *
; *   Input - w     controls in flag   output in w   *
; *         Inverts input to output
process_curve
      movwf   process_temp      ; Save value in w
      btfsc   flag,switch         ; Switching required ??
      goto   process_switching   ; yes,
      btfsc   flag,curve         ; Cuve or linear ??
      goto    process_scurve      ; Curve
process_linear
      comf   process_temp,w      ; invert value in to w
      btfsc   STATUS,Z         ; If zero then
      movlw   .1               ; make value = 1
      return
process_switching
      btfss   process_temp,7      ; Look for 50 % value
      retlw   .254            ; < 50 % ( inverted value)
      retlw   .1               ; > 50 % ( inverted value)
process_scurve                  ; Do table lookup.
      movwf   tbllo            ; Store low table value
      movlw   HIGH (tablestart)   ; Get High Table value
      movwf   PCLATH            ; store High Table value
      movlw   Low (tablestart)   ; add lower offset to low value
      addwf   tbllo,w            ;
      btfsc   STATUS,C         ; Carry from the addition ?
      incf   PCLATH,f         ; yes,
      ;movf   tbllo,w
      ;call    do_table
      ;clrf   PCLATH
      ;return
      ;addwf    PCL,f            ; Do Jump
      movwf   PCL               ; Do Jump
tablestart
      retlw .255
      retlw .249
      retlw .243
      retlw .238
      retlw .234
      retlw .230
      retlw .227
      retlw .223
      retlw .221
      retlw .218
      retlw .215
      retlw .213
      retlw .211
      retlw .209
      retlw .207
      retlw .205
      retlw .203
      retlw .202
      retlw .200
      retlw .198
      retlw .197
      retlw .195
      retlw .194
      retlw .193
      retlw .191
      retlw .190
      retlw .189
      retlw .188
      retlw .187
      retlw .185
      retlw .184
      retlw .183
      retlw .182
      retlw .181
      retlw .180
      retlw .179
      retlw .178
      retlw .177
      retlw .176
      retlw .175
      retlw .175
      retlw .174
      retlw .173
      retlw .172
      retlw .171
      retlw .170
      retlw .169
      retlw .169
      retlw .168
      retlw .167
      retlw .166
      retlw .166
      retlw .165
      retlw .164
      retlw .163
      retlw .163
      retlw .162
      retlw .161
      retlw .161
      retlw .160
      retlw .159
      retlw .159
      retlw .158
      retlw .157
      retlw .157
      retlw .156
      retlw .155
      retlw .155
      retlw .154
      retlw .154
      retlw .153
      retlw .152
      retlw .152
      retlw .151
      retlw .151
      retlw .150
      retlw .149
      retlw .149
      retlw .148
      retlw .148
      retlw .147
      retlw .147
      retlw .146
      retlw .145
      retlw .145
      retlw .144
      retlw .144
      retlw .143
      retlw .143
      retlw .142
      retlw .142
      retlw .141
      retlw .141
      retlw .140
      retlw .139
      retlw .139
      retlw .138
      retlw .138
      retlw .137
      retlw .137
      retlw .136
      retlw .136
      retlw .135
      retlw .135
      retlw .134
      retlw .134
      retlw .133
      retlw .133
      retlw .132
      retlw .132
      retlw .131
      retlw .131
      retlw .130
      retlw .130
      retlw .129
      retlw .129
      retlw .128
      retlw .128
      retlw .127
      retlw .127
      retlw .126
      retlw .126
      retlw .125
      retlw .125
      retlw .124
      retlw .124
      retlw .123
      retlw .123
      retlw .122
      retlw .122
      retlw .121
      retlw .121
      retlw .120
      retlw .120
      retlw .119
      retlw .119
      retlw .118
      retlw .118
      retlw .117
      retlw .117
      retlw .116
      retlw .116
      retlw .115
      retlw .115
      retlw .114
      retlw .114
      retlw .113
      retlw .113
      retlw .112
      retlw .112
      retlw .111
      retlw .111
      retlw .110
      retlw .110
      retlw .109
      retlw .109
      retlw .108
      retlw .108
      retlw .107
      retlw .107
      retlw .106
      retlw .106
      retlw .105
      retlw .105
      retlw .104
      retlw .104
      retlw .103
      retlw .103
      retlw .102
      retlw .102
      retlw .101
      retlw .100
      retlw .100
      retlw .99
      retlw .99
      retlw .98
      retlw .98
      retlw .97
      retlw .97
      retlw .96
      retlw .95
      retlw .95
      retlw .94
      retlw .94
      retlw .93
      retlw .92
      retlw .92
      retlw .91
      retlw .91
      retlw .90
      retlw .89
      retlw .89
      retlw .88
      retlw .87
      retlw .87
      retlw .86
      retlw .85
      retlw .85
      retlw .84
      retlw .83
      retlw .83
      retlw .82
      retlw .81
      retlw .81
      retlw .80
      retlw .79
      retlw .78
      retlw .78
      retlw .77
      retlw .76
      retlw .75
      retlw .74
      retlw .74
      retlw .73
      retlw .72
      retlw .71
      retlw .70
      retlw .69
      retlw .68
      retlw .68
      retlw .67
      retlw .66
      retlw .65
      retlw .64
      retlw .63
      retlw .62
      retlw .61
      retlw .59
      retlw .58
      retlw .57
      retlw .56
      retlw .55
      retlw .54
      retlw .52
      retlw .51
      retlw .50
      retlw .48
      retlw .47
      retlw .45
      retlw .43
      retlw .42
      retlw .40
      retlw .38
      retlw .36
      retlw .34
      retlw .32
      retlw .30
      retlw .27
      retlw .25
      retlw .22
      retlw .19
      retlw .16
      retlw .12
      retlw .8
      retlw .3
      retlw .0
      retlw .0
      retlw .0
      retlw .0
      retlw .0
      END                       ; directive 'end of program
« Respuesta #3 en: 24 de Noviembre de 2007, 08:11:14 »
aqui os lo pongo completo
Desconectado alogic.on
« Respuesta #4 en: 24 de Noviembre de 2007, 15:51:40 »
hola
podrias si no es mucho pedir, explicar que hace el programa y ver si lo podemos enfocar desde otro punto de vista, no me entra en el coco que hace el programa
he visto alguna cosilla que a lo mejor es una tonteria. para utilizar la tabla tablestart lo tienes escrito así
      movwf   PCL               ; Do Jump
tablestart
      retlw .255
      retlw .249
      retlw .243
      retlw .238
      retlw .234
      retlw .230
y creo que deberia de ser asi, que es como esta en el tutorial de tablas que me enviaste
La tabla de la verdad se sitúa desbordando los primeros 256 bytes de memoria de programa.
ORG .254 ; Cerca del borde de la primera página de 256 bytes.
TablaVerdad                               ; Posición 0x00FE de memoria de programa (PCH-PCL).
movwf PCL                                           ; El salto dentro de la tabla: PCH=PCLATH, PCL=W.
retlw b'00001010'                                 ; (Configuración 0). Posición 0x00FF.
retlw b'00001001'                                    ; (Configuración 1). Posición 0x0100.
retlw b'00100011'                                   ; (Configuración 2). Posición 0x0101.
retlw b'00001111'                                 ; (Configuración 3). Posición 0x0102.
retlw b'00100000'                                 ; (Configuración 4). Posición 0x0103.
retlw b'00000111'                                 ; (Configuración 5). Posición 0x0104.
retlw b'00010111'                                 ; (Configuración 6). Posición 0x0105.
retlw b'00111111'                                 ; (Configuración 7). Posición 0x0106.
END
ademas que si te fijas utilizas movwf pcl este pone el valor de w en pcl y si no esta alprincipio de pagina deberias usar addwf pcl de esta forma da casi igual en que posicion este la tabla
un saludo espero te ayude
« Respuesta #5 en: 24 de Noviembre de 2007, 16:13:39 »
Gracias por contestar!
esto es un DMX Dimmer
que se controla con entrada analoga de 0 a 10 Voltio, pero solo son 4 canales, si te fija en el circuito donde esta mi projecto alli esta el Circuito, bien tambien se controla DMX pero no me funciona y creo que el problema radica en la Direciones de los canales, como puede apreciar el Circuito tiene un Dip switch para configurarlo, que puede ser o analogo o digital DMX y la forma de controlarlo que puede ser linear dandole una Curva linear o Switch, yo llevo ya 2 semana dandole vuelta y pensando que eran la Resistencia ARRAY que van a los puerto, la cambie de 100k 10k y ahora la tengo a 1k y  aun asi nada :?
Re: Tiro los Guante con el DMXPACK!!!!!
« Respuesta #6 en: 02 de Diciembre de 2007, 14:16:31 »
 :x :x :x Tiro los Guantes  :x :x
« Respuesta #7 en: 02 de Diciembre de 2007, 15:58:10 »
¿No era problema con el DIP Switch?
« Respuesta #8 en: 02 de Diciembre de 2007, 18:38:14 »
No manolo!
te explico, yo tengo el Hex y el ASM lo probe con los dos, claro que el Hex lo baje del tipo, ahora bien cuando lo compilo y uso la opcion Basic=1 para usarlo con los LED me funciona raro, es decir la parte analogo sin activar el DIP funciona y cuando pongo la direcion 1 del DIP no me funciona, mido la señale en la entrada del Optocoople y no me sale nada pero cuando lo hago analogo sin activar el DIP en posicion 0 todos y le pongo con un poti y una pila 9Volt me fuciona :x
los DIP switch se que estan bien de acuerdo al Circuito, y yo pienso que es algo en el codio, porque ni los LED me funcionan como deben ser, es decir le invierto la señale de entrada DMX para que me de error y el LED no hace nada, siempre esta activo como Señal es OK!
 :x :x :x    : Tiro los Guante :x :x
« Respuesta #9 en: 03 de Diciembre de 2007, 08:28:33 »
Suele suceder que por olvido u otra razon menos tonta, el hex y el archivo fuente no son de la misma version, prueba escribirle al autor a ver si es asi, comentale tus problemas, a ver si se apiada de ti y te da el fuente original y correcto... ;-) ;-) :z)
Desconectado jfh900
« Respuesta #10 en: 03 de Diciembre de 2007, 09:33:22 »
Yo creo que no deberías de tirar la toalla. Llevas un tiempo sobre el proyecto y seguro que alguien te puede ayudar. Yo no trabajo en ensamblador y por consiguiente no te puedo ayudar, pero seguro que los compañeros de ASM te pueden echar una mano. Por otra parte si decides portarlo a "C", seguro que te podremos ayudar.
Un saludo y ánimo, que no se diga que unos cuantos ceros y unos pueden más.
Desde España Jesús
« Respuesta #11 en: 04 de Diciembre de 2007, 13:27:01 »
gracias Jesus!
eso espero! que alguien me pueda mirar el codigo y ver lo que anda mal, yo no espero que me haga nadie el codigo, simplemente de corregir los fallos,
  ya he probado con uC y nada concreto, tengo la sensacion que son los FUSES ya que los DIP SWITCH no reacionan para nada,
 :-/ :-/solo espero sugerencia  :-/ :-/
Desconectado jfh900
« Respuesta #12 en: 04 de Diciembre de 2007, 19:20:33 »
¿Se podría hacer una simulación en Proteus para probar el programa?
Desde España Jesús
« Respuesta #13 en: 04 de Diciembre de 2007, 20:33:37 »
Hola Jesus!
con el proteus no soy muy fino y no lo he probado, pero si tu pudiera me haria ese favor, aunque voy intentarlo despues!
 :mrgreen: gracias  Jesus por la Sugerencia  :mrgreen:
Desconectado jfh900
« Respuesta #14 en: 04 de Diciembre de 2007, 20:38:41 »
Si tienes el esquema no tendría problema en pasarlo a Proteus.
Desde España Jesús
