Autor Tema: al fin una buena, pin mapping  (Leído 4399 veces)
Desconectado psykhon
« en: 21 de Abril de 2007, 21:46:52 »
Microchip Technology announced eight members of the PIC24F 16-bit microcontroller family, which extend the line into smaller 28- and 44-pin packages with 16 to 64 Kbytes of Flash program memory and up to 8 Kbytes of RAM. The PIC24FJ64GA004 family allows the flexible use of all onboard peripherals, by enabling designers to map them to the pin they desire through the "peripheral pin select" pin-mapping function.
The family is designed to meet a wide range of design engineering needs across a broad spectrum of industries. Specific application examples include consumer (security systems, heating control, audio equipment); automotive (body control, steering systems); instrumentation/measurement (scales, medical instruments and monitoring); industrial (building monitor-and-control systems, security/access systems, sensors).
In addition to peripheral pin select, this PIC24F family features two independent channels of I2C, UART and SPI communications. These channels allow the microcontrollers to communicate to a number of devices over multiple protocols. Additionally, the family is designed for transition to other members in the PIC24F family and for migration to other families in Microchip's 16-bit portfolio, including the PIC24H and dsPIC33 families, through code compatibility. This compatibility enables the migration from a 16 MIPS PIC24F microcontroller to a 40 MIPS dsPIC33 digital signal controller.
All eight members of the family are supported by MPLAB Integrated Development Environment with its visual device initializer component, which graphically assists designers in mapping pins and initializing code for the on-chip peripheral pin select pin-mapping function. The MPLAB C30 C compiler provides code densities, along with math and peripheral libraries. For emulation and debugging, the MPLAB REAL ICE and the MPLAB ICD 2 tool are offered.
No, no se lo que estoy haciendo. Nadie sabe que estoy haciendo. Por eso se llama "Investigacion".
Desconectado maunix
    • Mi Sitio Web Personal
Re: al fin una buena, pin mapping
« Respuesta #1 en: 22 de Abril de 2007, 11:38:16 »
Genial!!
« Respuesta #2 en: 23 de Abril de 2007, 01:46:36 »
Alucinante; pin mapping, encapsulados DIP, y sólo 2€  :mrgreen:
Desconectado maunix
« Respuesta #3 en: 23 de Abril de 2007, 13:06:52 »
Si... cuando veo estos precios es para pensar seriamente ¿cuánto les sale hacer un microcontrolador?
Si sale 2€, algo así como 2,5u$s  y teniendo en cuenta la tasa de fallos en la fabricación, más el costo de la fábrica, más el costo de la ingeniería en Investigación y Desarrollo, más el costo de publicidad, merchandising, cadena de distribución, sueldos.... ufff  y a pesar de todo eso, al público está a 2.5 dólares!!
Supongo que les debe salir 0.1u$s ...
« Respuesta #4 en: 23 de Abril de 2007, 21:19:49 »
y si, mas si contamos qie no son o mas masivo que hay. Por otro lado los costos no deben ser mucho ya que no usan gran tecnologia y el nivel de miniaturizacion no debe ser la gran cosa (alguno sabe cuantos micrones tiene un transistor de los pic??)
Desconectado manex_1987
« Respuesta #5 en: 24 de Abril de 2007, 14:29:50 »
oh!!! sencillamente sensacional!! Ya era hora!!! Estoy que no cago!  :-/ :-/ :-/ :-/
Facilitará muchisimas cosas!
« Respuesta #6 en: 24 de Abril de 2007, 14:39:34 »
Cuidado con las emociones que el estreñimiento es peligroso. Lo que no sale por su sitio, al final tiene que salir sea como sea...
Desconectado PalitroqueZ
    • Electrónica Didacta
« Respuesta #7 en: 24 de Abril de 2007, 15:03:31 »
estoy caido de la mata y mal con el english, ¿que significa en criollo pin mapping?
Friedrich August von Hayek
« Respuesta #8 en: 24 de Abril de 2007, 15:06:27 »
Estos PIC tienen una característica novedosa: permiten jugar con la disposición física de algunos de sus periféricos entre 16 de sus pines.
Dicho en cristiano: si necesitas la USART en el pin 18 y el SPI en el 20 podrás hacerlo. Si mañana lo necesitas al contrario, basta con cambiar un registro del PIC y se cambiará.
Obviamente con la limitación de que sólo se pueden cambiar 16 de sus pines, y no todos los periféricos pueden mutar de sitio, pero algo es algo.
