Autor Tema: problemas con EPIWIN  (Leído 2753 veces)
Desconectado wiston
« en: 12 de Marzo de 2007, 01:48:18 »
BUENAS NOCHES A TODOS :
TENGO UN PROBLEMA EN LA INSTALACION DE EPIWIN RESULTA QUE LO INSTALABA EN MI PC NORMALMENTE  Y ALGUN DIA TUVE QUE VOLVER A INSTALAR TODO EL SISTEMA OPERATIVO Y OVIAMENTE EL EPIWIN Y AHORA PASA QUE APARECE UN UN ERROR DE QUE NO TENGO INSTALADO EL DRIVER DE EPIWIN "UNABLE TO START DRIVER PICLPTNT.SYS, HERROR 997 (3E5 hex)"  FUI AL README.TXT Y ENCONTRE ESTO:
 Windows NT/2000/XP Driver Installation:
Usually, running the EPIC Windows programming software will automatically
load the required driver, PICLPTNT.SYS.  In some cases and with some
permissions, the driver may not be properly loaded under NT/2000/XP.  A
program, NTINST, is included with the EPIC software to install or remove
the EPIC Windows NT/2000/XP driver (you must be logged in as an
administrator).
To install the NT/2000/XP driver, from the EPIC subdirectory, enter:
        ntinst /install
If the EPIC programming software is reinstalled or moved to a different
directory, the Windows NT/2000/XP registry may try to start the PICLPTNT
service from the wrong directory.  To reset the registry key , from the
        ntinst /remove
You may receive an error, but it should remove the driver anyway.
If you can't remove the driver using this method, you can delete the
registry key using REGEDIT.  Editing the registry is an advanced operation
that should only be performed by those well versed in Windows operating
systems.
The key to delete is:
\HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\SERVICES\PICLPTNT.
HE TRATADO DE HACER LO QUE ME DICE AQUI PERO NO HE PODIDO INSTALARLO NO SE SI ESTOY ENTENDIENDO MAL EL INGLES QUE NO LO HABLO .
AGRADECERIA SI ALGUIEN ME DA UNA AYUDA
WISTON
Desconectado PalitroqueZ
    • Electrónica Didacta
Re: problemas con EPIWIN
« Respuesta #1 en: 12 de Marzo de 2007, 12:53:51 »
intenta varias veces ntinst /remove y después ntinst /install. tiene que funcionar
ve que dice el mensaje de error, te puede servir de ayuda.
Salu2
Pedro
Friedrich August von Hayek
Desconectado SavageChicken
« Respuesta #2 en: 12 de Marzo de 2007, 13:03:53 »
Parece que hay un problema de permisos, deberías asegurarte de que tienes privilegios de administrador para istalar el driver o el EPICWIN
Salud  8)
No hay preguntas tontas...
