Autor Tema: Familia LPC de phillips  (Leído 9803 veces)
Desconectado psykhon
« en: 18 de Febrero de 2007, 15:32:37 »
transcripcion de wikipediawikipedia sobre la familia LPC de phillips (ahora NXP)
LPC2000
From Wikipedia, the free encyclopedia
Jump to: navigation, search
LPC2000 is a series of microcontrollers from NXP Semiconductors. The 16/32-bit LPC2000 family is based on a 1.8V ARM7TDMI-S core operating at up to 70 MHz together with a wide range of peripherals including multiple serial interfaces, 10-bit ADC/DAC, timer, capture compare, PWM, USB and external bus options. These controllers are designed for use in a range of applications requiring high performance and low power consumption in a cost-effective package.
Flash memory ranges from 32Kb to 512Kb; RAM ranges from 4Kb to 32Kb.
Contents
[hide]
    * 1 Optimizing for price
    * 2 LPC2300
    * 3 LPC2400
    * 4 External links
[edit] Optimizing for price
The LPC2141, LPC2142, LPC2144, LPC2146, and LPC2148 are all 64-pin devices. Memory ranges from 32Kb to 512Kb of flash. They support multiple peripherals, including Full speed USB 2.0. Develop with the LPC2148, as it has 512Kb of memory. When you have finished development, you can slot in the cheapest ARM microcontroller that still provides you enough flash for your application. For example, if your application was only 60Kb, you could simply use the LPC2142.
[edit] LPC2300
The LPC23xx series operates at 72MHz with up to 512KB of zero-wait state on-chip flash. More significant is its ability to simultaneously run the application, USB FS, CAN, and Ethernet. This is mainly achieved by the industry's only 2 AHB bus architecture in an ARM7-based MCU.
[edit] LPC2400
The LPC24xx series is built on a 2-AHB bus architecture. Like the LPC23xx series, the LPC24xx also features Ethernet, USB FS, CAN and a SD/MMC interface. In addition, the LPC24xx adds an USB Host/OTG, an external bus, and higher I/O count, making this simply the most powerful series of ARM7-based MCUs in the marketplace.
No, no se lo que estoy haciendo. Nadie sabe que estoy haciendo. Por eso se llama "Investigacion".
Desconectado manuelroin24
Re: Familia LPC de phillips
« Respuesta #1 en: 19 de Febrero de 2007, 16:18:16 »
Esta es una de las familias que mas me interesara aprender ya q son los mas usados en las empresas , a ver si aqui algun experto nos da una manito
El conocimiento se consigue a base de esfuerzo...
« Respuesta #2 en: 19 de Febrero de 2007, 17:58:41 »
porque crees que se usa mas en las empresas?
« Respuesta #3 en: 19 de Febrero de 2007, 19:36:02 »
Bueno al menos en la poca experiencia que he tenido en sistemas de control en maquinas de publicidad modernas HP usa mucho los micros de philips en sus mainboard's y tambien usan mucho los FPGA de ALTERA
« Respuesta #4 en: 19 de Febrero de 2007, 21:23:09 »
bueno, te cuento que parecen ser los unicos que entran a Argentina, si bien atmel tiene representantes nadie tiene stock
Desconectado 5GTT
« Respuesta #5 en: 27 de Febrero de 2007, 23:05:12 »
Creo que este enlace biene de perlas en este post:
http://www.mcu123.com/new/Article_Show.asp?ArticleID=183
Desconectado Darukur
    • Informacion, recursos y ejemplos para desarrollos con microcontroladores
« Respuesta #6 en: 11 de Junio de 2007, 11:31:04 »
Gente si les interesa en Argentina la linea LPC la trae ELKO/ARROW.
El que no sabe lo que busca no entiende lo que encuentra.
Mi Pagina Web:  http://www.sistemasembebidos.com.ar
Mi foro:             http://www.sistemasembebidos.com.ar/foro/
« Respuesta #7 en: 05 de Octubre de 2007, 11:16:50 »
Hoy me acaban de dar unas samples del LPC2134FBD64 asi que empezare a analizarlos en el corto plazo y a molestarlos con mis preguntas incesantes   :D
Espero poder "masterizarlos" en el mediano plazo, los que si los AT91SAM7 ya los tengo y no pienso soltarlos me llevo su tiempo conocerlos y me encariñe... :-/
Salutes
« Respuesta #8 en: 05 de Octubre de 2007, 20:32:46 »
los compraste en elko o son samples que te envio nxp?
« Respuesta #9 en: 06 de Octubre de 2007, 10:56:54 »
Si, perdon. Me falto citar que era respuesta a mi post anterior.
Me los proveyo la gente de ELKO/ARROW, me dieron unos ARM9 de Freescale pero me mori de risa al ver que eran BALL.
Me parece que tienen mucho mejor precio que la gente de Electrocomponentes, estoy esperando su lista de precios.
Ahh, todavia no me llegaron los UlinK de micro4you.
« Respuesta #10 en: 06 de Octubre de 2007, 12:05:01 »
haceme la gauchada y pasame todo lo que te pasen, por cierto, que micro era el arm9? te cuento que salvo rarisimas excepciones no vas a encontrar muchos que no sean bga, hay uno de st (con flash) y el conocidisimo at91rm9200
« Respuesta #11 en: 10 de Octubre de 2007, 00:27:00 »
La verdad no me fije, cuando me lo ofrecieron abri la bolsa antiestatica y vi que era ball asi que lo meti denuevo adentro y se lo devolvi  :?.
Me quede con los LPC2134 que por lo menos los podemos utilizar ahora.
Si tengo novedades te aviso.
« Respuesta #12 en: 10 de Octubre de 2007, 14:10:48 »
con pasame lo que te pasen me referia a precios y que micros tienen en stock. gracias
« Respuesta #13 en: 10 de Octubre de 2007, 19:41:30 »
:mrgreen: Si te entendi bien no te preocupes, cuando me lo pasen al toque te lo paso.
Ojala me consigan samples del AT91SAM7, ya le tome cariño...
Desconectado cristian_elect
« Respuesta #14 en: 15 de Mayo de 2008, 14:26:42 »
Yo tambien tenia interes el lo arm pero aqui en peru no hay a la venta.
Ya tengo bastante informacion sobre los lpc2000 ya los simule en keil pero no hay para comprar
tendria que traerlos.
Si que lo tiene para vender me avisan.
Su grabador es sencillo por que tiene bootloader
