Autor Tema: Easy SD/MMC y PIC18F4550  (Leído 6537 veces)
adbensi
  • Visitante
« en: 20 de Diciembre de 2006, 20:50:47 »
Good day.
I have the MikroC version 5.0.0.3, and I am to try make one project with Mmc_Fat16_Test example, but it doen´t work. The funcion Mmc_Fat_Init(&PORTC,2) return false :(
What is wrong? Can to see my circuit bellow ?
I have connected these pins in MMC card - PIC
SD/MMC PIN - PIC18F4550
1 CS       - RC2/CCP1 pin 17 OUTPUT
2 SDI      - RC7/SDO  pin 26 OUTPUT
3 GND
4 3.3 Vcc
5 SCK      - RB1/SCL  pin 34 OUTPUT
6 GND
7 SDO      - RB0/SDI  pin 33 INPUT
    TRISA = 0b00100000; // SS must have TRISA<5> bit set, to GND.
    TRISB = 0b00000001; // SDI is automatically controlled by the SPI module.
      // SCK (Master mode) must have TRISB<1> bit cleared.
    TRISC = 0b00000000; // SDO must have TRISC<7> bit cleared
    TRISD = 0b00000000;
    TRISE = 0b00000000;
Device Flags to PIC18F4550 20MHz HS_PLL:
PLL_div_5, CPU_div_osc1_PLL2, FOSC_HS_PLL_HS, FCMEM_OFF, IESO_OFF,
PWRT_OFF, BOR_OFF, VRGEN_OFF, WDT_OFF, MCLRE_EN, CCP2MX_OFF
I have conected the MMC card (try 8MB CE and 16MB Cannon) in PIC18F4550.
The MMC card works whith Standard Card Reader (it is formated in WinXP - format G: /FS:FAT /A:512).
My code of Mmc_Fat16_Test (see Mmc_Fat16_Test.zip to full version):
void main() {
    TRISD = 0b00000000;
    TRISE = 0b00000000;
     //--- set down STATUS Led
     PORTA.F0 = 0;
     Delay_ms(100);
     //--- set up USART for the file read
     Usart_Init(9600);
     Delay_ms(100);
     //--- init the FAT library
     Spi_Init_Advanced(MASTER_OSC_DIV16, DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
     Delay_ms(250);
     if (Mmc_Fat_Init(&PORTC,2)) {
         //--- Test routines. Uncomment them one-by-one to test certain features
         M_Create_New_File();
           while(1){
             PORTA.F0 = !PORTA.F0;
             Delay_ms(1000);
     else {
       I_Write_Str(FAT_ERROR);
       while(1);
Thanks a lott,
Alexandre.
Desconectado raus
Re: Easy SD/MMC y PIC18F4550
« Respuesta #1 en: 21 de Diciembre de 2006, 10:36:15 »
Hi!
I'm developing a similar project but, as I still haven't started with the code, the only thing I can do is to ask you about the schematics:
-Have you set the pull-up resistors specified by the SD specifications?
-Are you feeding the card with the proper 3V, rather than 5V? (if this is the problem you can either put a voltage regulator between +5V source and the card voltage input, or use one of the PICs that can be feeded with 3V)
-Are you using any kind of TTL buffer between the card and the pic? (in case your pic works at +5V)
-Have you formatted the card in FAT16 before inserting in the socket?
I know this questions are very basic, but if you don't respect them, maybe this is the cause of your problems. When I start coding, I'll post my results here.
Good luck!!
Visita mi blog sobre tecnología y marketing:
http://franciscobenito.es
adbensi
  • Visitante
« Respuesta #2 en: 21 de Diciembre de 2006, 20:06:27 »
Hellow Raus, buenos dias,  :-/
 Estoy con alguns resistores en las patitas del MMC card para hacer la funcion Pull-up, espero estar correcto con my circuito. Por favor, mira el archivo anexo circuito.gif
 Yo va buscar regusladores y resistores mejores para hacer la division de tensão, estoy alimentando la tarjeta MMC con 3.1Vcc.
 No tieno TTL buffer in circuit, puesso hacer asy conforme la imagem anexa?
 E por fim, gracias por su ayuda, acredito que estoy usando sistema FAT (format g: /FS:FAT).
 En WinXP FAT16 no estas disponible, en outras bibliografias dizem que FAT és na verdade FAT16. Acredito que seja FAT = FAT16 porque las tarjetas são menores que 32MB, e no se puede formatar tarjetas < 32MB con FAT32. :)
uno grande abraço :D
Alexandre.
Desconectado raus
« Respuesta #3 en: 22 de Diciembre de 2006, 05:23:41 »
Ahora estoy en el trabajo y no puedo revisarlo con mas calma, pero en principio te diria que me resulta un poco raro que no haya en ese esquematico ninguna señal de tierra (GND), no?
adbensi
  • Visitante
« Respuesta #4 en: 22 de Diciembre de 2006, 08:41:12 »
Bom dia Rau!
 Sy, tieno GND (pin 12 y 31 del PIC) y Vcc (pin 11 y 32 del PIC). Me desculpa não ter-lo conectado na imagem. Estoy usando ploto-board, y la imagem en eagle és solo explicacion, me gusta anexar la imagem del ploto-board :) És muy primário :)
 Me ayda muito sy pueder revisarlo, tieno duda en algunas partes  :?
  No entendo porque el datasheet informa que TRISA<5> debes ser ativado, tieno duda se RA5 en GND ou Vcc :(  (datasheet del 18F4550 pg 195)
  TRISD = 0b00000000;
  TRISE = 0b00000000;
Gracias, :D
Alexandre.
Desconectado bily
SD/MMC y PIC18F4550
« Respuesta #5 en: 11 de Agosto de 2007, 13:41:31 »
alguien tiene el codigo funcionando y probado estoy intentando funcionar pic16f877a y nada alguien que me ayude..
