Autor Tema: Error 103 con proteus (adjunto circuito)  (Leído 10359 veces)
Desconectado inaltec
« en: 02 de Noviembre de 2006, 08:40:01 »
Hola, cuando simulo con proteus el circuito me da un error 103, os adjunto todo el log al final del mensaje.
Si quito todo la parte de leds y de transistores, el circuito funciona perfectamente. No se si es un problema de que el circuito esta mal o es una problema de configuración de proteus. Utilizo Proteus v6.9 Sp4
Si alguien está interesado le puedo enviar los archivos del circuito.
Muchas gracias y un saludo.
SIMULATION LOG
Design:   C:\Documents and Settings\Eduardo\Escritorio\Interjuego Raul\simor\circuito electronico\circuito\simor.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  01/11/06
Modified: 02/11/06
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [EA629B38]...
PROSPICE Release 6.9 SP4 (C) Labcenter Electronics 1993-2006.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Building circuit...
Instantiating SPICE models...
[U1] PIC18 model release 6.80 SP1 simulating 'PIC18F442' device.
[U1] Loaded 256 bytes of persistent EEPROM data.
[U1] Loading HEX file '..\simor\simor.HEX'.
[U1] Read total of 192 bytes from file '..\simor\simor.HEX'.
[U1] Loaded 178 program bytes and 0 data bytes.
[U1] Execution (instruction) clock frequency is 4.00MHz
[SPICE] Starting Gmin stepping: 120 steps
Warning: [SPICE] singular matrix:  check nodes AA4_IP1#branch and AA4_IP1#branch
Warning: [SPICE] Gmin step
  • failed: GMIN=1
Warning: [SPICE] Gmin stepping failed
[SPICE] starting source stepping
Warning: [SPICE] Source step
  • failed: source factor = 0
[SPICE] Error 103 - Too many iterations without convergence.
Real Time Simulation failed to start
Totaliters=0, Totalsteps=0, Goodsteps=0, Badsteps=0
Warning: [U1] at 0.00 (PC=0x0000): No instruction cycles were executed - processor may never have made it out of reset!
Real Time Simulation FAILED.
Desconectado micro_cadaver
    • blog microembebidos
Re: Error 103 con proteus (adjunto circuito)
« Respuesta #1 en: 02 de Noviembre de 2006, 10:02:14 »
hola inaltec, a primera vista no se lo q pueda ser, he bajado tu archivo y quisiera q me pases los demas archivos del circuito para simularlo tb a ver si me sale el mismo error.  :o
a cosechar!!!... :P
pic32... ahi voy....
aguante el micro 16f84  !!!!
Desconectado lord_10
    • My Blog
« Respuesta #2 en: 03 de Noviembre de 2006, 02:22:49 »
Adjunta los archivos para checarlo bien ok  :-), ah y recuerda que donde tengas los archivos la directiva no debe contener varias subcarpetas si no de lo contario marca error.
..::  3D5F ™ ::..  AHC
"Tan sólo hace falta una pequeña idea, para hacer un gran sueño realidad."
« Respuesta #3 en: 03 de Noviembre de 2006, 04:54:10 »
Ya lo tengo solucionado,
da error cuando le pongo a la entrada VI de U2 más de 10V. Dejaré esa tensión en 10V.
Gracias a todos.
