y como hago para que el resultado me de en com flotante osea que no solo me muestre 4volts 3volt sino 3.1 - 2.5 ejemplo
tengo que modificar el programa este es mi programa
y mi ejemplo en proteus 6.7 sp3
'* Name : UNTITLED.BAS *
'* Author : [select VIEW...EDITOR OPTIONS] *
'* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 22/09/2006 *
'* Version : 1.0 *
'* Notes : *
DEFINE OSC 20
DEFINE LCD_RWREG PORTD
DEFINE LCD_RWBIT 2
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_EREG PORTD
DEFINE LCD_EBIT 3
DEFINE LCD_RSREG PORTD
DEFINE LCD_RSBIT 1
' Define ADCIN parameters
Define ADC_BITS 10 ' Set number of bits in result
Define ADC_CLOCK 3 ' Set clock source (3=rc)
Define ADC_SAMPLEUS 50 ' Set sampling time in uS
adval var word ' Create adval to store result
TRISA = %11111111 ' Set PORTA to all input
ADCON1 = %10000010 ' Set PORTA analog and right justify result
Pause 500 ' Wait .5 second
loop: ADCIN 0, adval ' Read channel 0 to adval
Lcdout $fe, 1 ' Clear LCD
Lcdout "Value: ", salida ' Display the decimal value
Pause 100 ' Wait .1 second
Goto loop ' Do it forever
End
