;- coder: Alexandros Zahariadis -
;- Thessaloniki- Greece -
- email: bitmaniac@yahoo.
COM -;=------------------------------=
;PIC61F648A
(20Mhz crystal
) - 4Mhz
IS ok
,too
'NOKIA 3310 LCD MODULE PINOUT
'as viewed from the back (left -> right)
'1 vcc
'2 sclk portb.7
'3 sda portb.6
'4 d/!c portb.5
'5 !cs portb.4
'6 gnd
'7 Vout
'8 !rst portb.3
INCLUDE "modedefs.bas"
defINE OSC 20
CMCON = %00000111 ' Make PortA digital
TRISA = %00000000
TRISB = %00000000
Lcd_DC var Portb.5
Lcd_CS var Portb.4
Lcd_SDA var Portb.6
Lcd_RST var Portb.3
Lcd_CLK var Portb.7
i var Byte
j var Word
k var Byte
b0 var byte
PosX var Byte
PosY var Byte
FontCache var Byte [6]
LcdStr var Byte [26]
Lcd_Data var Byte
Low Lcd_CS 'Chip selected
GOSUB Lcd_INIT
GOSUB Lcd_Clear
'set contrast
Low Lcd_DC
SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ $21,$a7,$20 ]
start:
PosX=0:PosY=0:GOSUB Lcd_GotoXY
FOR i=0 TO 13
lookup i,["NOKIA LCD TEST"],j
lcdstr(i)=j
NEXT i
GOSUB Lcd_SentString
PosX=0:PosY=1:GOSUB Lcd_GotoXY
FOR i=0 TO 13
lookup i,["{} {} {} {} {}"],j
lcdstr(i)=j
NEXT i
PosX=0:PosY=2:GOSUB Lcd_GotoXY
FOR i=0 TO 13
lookup i,["{} GRAPHICS {}"],j
lcdstr(i)=j
NEXT i
PosX=0:PosY=3:GOSUB Lcd_GotoXY
FOR i=0 TO 13
lookup i,["{} {} {} {} {}"],j 'cars icons!
lcdstr(i)=j
NEXT i
PosX=0:PosY=4:GOSUB Lcd_GotoXY
FOR i=0 TO 13
lookup i,["84 X 48 PIXELS"],j
lcdstr(i)=j
NEXT i
PosX=0:PosY=5:GOSUB Lcd_GotoXY
FOR i=0 TO 13
lookup i,["ALEX BITMANIAC"],j
lcdstr(i)=j
NEXT i
PAUSE 1000
start2:
'invert screen mode
Low Lcd_DC
Lcd_Data= %00001101:GOSUB Lcd_SentByte ;invert
;Lcd_Data= %00001000:GOSUB Lcd_SentByte ;blank
pause 500
'normal screen mode
Low Lcd_DC
Lcd_Data= %00001100:GOSUB Lcd_SentByte
pause 3000
;GOSUB lcd_clear
GOTO start2
'LCD ROUTINE
Lcd_Init:
'RESET LCD
Low Lcd_RST
pause 20
High Lcd_RST
Low Lcd_CS : Low Lcd_DC
Lcd_Data= $21: GOSUB Lcd_SentByte 'LCD EXTENDED COMMANDS
Lcd_Data= $c8: GOSUB Lcd_SentByte 'SET LCD Vop (CONTRAST)
Lcd_Data= $06: GOSUB Lcd_SentByte 'SET TEMP COEFFICENT
Lcd_Data= $10: GOSUB Lcd_SentByte 'LCD BIAS MODE 1:48
Lcd_Data= $20: GOSUB Lcd_SentByte 'LCD STANDARD COMMANDS
Lcd_Data= $0c: GOSUB Lcd_SentByte 'LCD IN NORMAL MODE
RETURN
Lcd_SentByte:
SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ Lcd_Data ]
RETURN
Lcd_SentChar:
SELECT CASE lcd_data
CASE 48 '0
j = 156
CASE 49 '1
j = 162
CASE 50 '2
j = 168
CASE 51 '3
j = 174
CASE 52 '4
j = 180
CASE 53 '5
j = 186
CASE 54 '6
j = 192
CASE 55 '7
j = 198
CASE 56 '8
j = 204
CASE 57 '9
j = 210
CASE 32 'space
j = 216
CASE 43 '+
j = 222
CASE 45 '-
j = 228
CASE 46 '.
j = 234
CASE 42 '*
j = 240
CASE 58 ':
j = 246
CASE 124 'character '|' -> graphic!
FOR i=0 TO 5
LOOKUP2 i,[$7e,$95,$a1,$a1,$95,$7e],b0
fontcache(i)=b0:NEXT i:GOTO jump
CASE 123 'character '{' -> car half left
FOR i=0 TO 5
LOOKUP2 i,[$18,$5c,$ac,$5e,$1d,$1d],b0
CASE 125
FOR i=0 TO 5 'character '}' -> car half right
LOOKUP2 i,[$1d,$1d,$5f,$ac,$5c,$18],b0
CASE ELSE 'letters A-Z -capitals
j=(Lcd_Data-65) * 6
FOR i=0 TO 5
NEXT i
jump:
High Lcd_DC
SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ FontCache(0),FontCache(1),FontCache(2),FontCache(3),FontCache(4),FontCache(5) ]
RETURN
Lcd_SentString:
FOR k=0 TO 13 ' step -1
Lcd_Data=LcdStr(k)
;IF Lcd_Data=0 THEN RETURN
pause 80
GOSUB Lcd_SentChar
NEXT k
RETURN
Lcd_Contrast:
Low Lcd_DC
Lcd_Data=$C8:GOSUB Lcd_SentByte 'write data
RETURN
Lcd_Clear:
GOSUB Lcd_Home
High Lcd_DC
FOR i=1 TO 252
Lcd_Data=0:GOSUB Lcd_SentByte 'write data
NEXT i
RETURN
Lcd_Home:
RETURN
Lcd_GotoXY:
Low Lcd_DC
Lcd_Data=%01000000 | PosY :GOSUB Lcd_SentByte 'Y
Lcd_Data=%10000000 | PosX :GOSUB Lcd_SentByte 'X
RETURN
' Font DATA table
DATA $7E
11,$
11,$
11,$7E
00 '65 - A - 41 DATA $
7F,$
49,$
49,$
49,$
36,$
00 '66 - B - 42 DATA $3E
41,$
41,$
41,$
22,$
00 '67 - C - 43 DATA $
7F,$
41,$
41,$
22,$1C
00 '68 - D - 44 DATA $
7F,$
49,$
49,$
49,$
41,$
00 '69 - E - 45 DATA $
7F,$
09,$
09,$
09,$
01,$
00 '70 - F - 46 DATA $3E
41,$
49,$
49,$7A
00 '71 - G - 47 DATA $
7F,$
08,$
08,$
08,$
7F,$
00 '72 - H - 48 DATA $
00,$
41,$
7F,$
41,$
00,$
00 '73 - I - 49 DATA $
20,$
40,$
41,$
3F,$
01,$
00 '74 - J - 4A DATA $
7F,$
08,$
14,$
22,$
41,$
00 '75 - K - 4B DATA $
7F,$
40,$
40,$
40,$
40,$
00 '76 - L - 4C DATA $
7F,$
02,$0C
02,$
7F,$
00 '77 - M - 4D DATA $
7F,$
04,$
08,$
10,$
7F,$
00 '78 - N - 4E DATA $3E
41,$
41,$
41,$3E
00 '79 - O - 4F DATA $
7F,$
09,$
09,$
09,$
06,$
00 '80 - P - 50 DATA $3E
41,$
51,$
21,$5E
00 '81 - Q - 51 DATA $
7F,$
09,$
19,$
29,$
46,$
00 '82 - R - 52 DATA $
46,$
49,$
49,$
49,$
31,$
00 '83 - S - 53 DATA $
01,$
01,$
7F,$
01,$
01,$
00 '84 - T - 54 DATA $
3F,$
40,$
40,$
40,$
3F,$
00 '85 - U - 55 DATA $
1F,$
20,$
40,$
20,$
1F,$
00 '86 - V - 56 DATA $
3F,$
40,$
38,$
40,$
3F,$
00 '87 - W - 57 DATA $
63,$
14,$
08,$
14,$
63,$
00 '88 - X - 58 DATA $
07,$
08,$
70,$
08,$
07,$
00 '89 - Y - 59 DATA $
61,$
51,$
49,$
45,$
43,$
00 '90 - Z - 5A DATA $3E
51,$
49,$
45,$3E
00 '48 - 0 - 30 DATA $
00,$
42,$
7F,$
40,$
00,$
00 '49 - 1 - 31 DATA $
42,$
61,$
51,$
49,$
46,$
00 '50 - 2 - 32 DATA $
21,$
41,$
45,$4B
31,$
00 '51 - 3 - 33 DATA $
18,$
14,$
12,$
7F,$
10,$
00 '52 - 4 - 34 DATA $
27,$
45,$
45,$
45,$
39,$
00 '53 - 5 - 35 DATA $3C
,$4A
49,$
49,$
30,$
00 '54 - 6 - 36 DATA $
01,$
71,$
09,$
05,$
03,$
00 '55 - 7 - 37 DATA $
36,$
49,$
49,$
49,$
36,$
00 '56 - 8 - 38 DATA $
06,$
49,$
49,$
49,$3E
00 '57 - 9 - 39 DATA $
00,$
00,$
00,$
00,$
00,$
00 '32 - - 20 DATA $
08,$
08,$3E
08,$
08,$
00 '43 - + - 2B DATA $
08,$
08,$
08,$
08,$
08,$
00 '45 - - - 2D DATA $
00,$
60,$
60,$
00,$
00,$
00 '46 - . - 2E DATA $
14,$
08,$3E
08,$
14,$
00 '42 - * - 2A DATA $
00,$
36,$
36,$
00,$
00,$
00 '58 - : - 3A
