Encontre el siguiente registro en el datasheet, con ésto entiendo que debo modificar el bit 13 (hacerlo 0) para que no deje leer el código, lo que no se es cómo hacerlo en el PB Pro,
REGISTER 14-1: CONFIGURATION WORD (ADDRESS 2007h)
bit 13 CP: Flash Program Memory Code Protection bit
1 = Code protection off
0 = All program memory code-protected
bit 12 Unimplemented: Read as ‘1’
bit 11 DEBUG: In-Circuit Debugger Mode bit
1 = In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins
0 = In-Circuit Debugger enabled, RB6 and RB7 are dedicated to the debugger
bit 10-9 WRT1:WRT0 Flash Program Memory Write Enable bits
For PIC16F876A/877A:
11 = Write protection off; all program memory may be written to by EECON control
10 = 0000h to 00FFh write-protected; 0100h to 1FFFh may be written to by EECON control
01 = 0000h to 07FFh write-protected; 0800h to 1FFFh may be written to by EECON control
00 = 0000h to 0FFFh write-protected; 1000h to 1FFFh may be written to by EECON control
For PIC16F873A/874A:
10 = 0000h to 00FFh write-protected; 0100h to 0FFFh may be written to by EECON control
01 = 0000h to 03FFh write-protected; 0400h to 0FFFh may be written to by EECON control
00 = 0000h to 07FFh write-protected; 0800h to 0FFFh may be written to by EECON control
bit 8 CPD: Data EEPROM Memory Code Protection bit
1 = Data EEPROM code protection off
0 = Data EEPROM code-protected
bit 7 LVP: Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit
1 = RB3/PGM pin has PGM function; low-voltage programming enabled
0 = RB3 is digital I/O, HV on MCLR must be used for programming
bit 6 BOREN: Brown-out Reset Enable bit
1 = BOR enabled
0 = BOR disabled
bit 5-4 Unimplemented: Read as ‘1’
bit 3 PWRTEN: Power-up Timer Enable bit
1 = PWRT disabled
0 = PWRT enabled
bit 2 WDTEN: Watchdog Timer Enable bit
1 = WDT enabled
0 = WDT disabled
bit 1-0 FOSC1:FOSC0: Oscillator Selection bits
11 = RC oscillator
10 = HS oscillator
01 = XT oscillator
00 = LP oscillator
Note 1: The erased (unprogrammed) value of the Configuration Word is 3FFFh.
¿Sería algo así?:
REGISTER_14-1 %0011110000000
