copiá todo lo de abajo en un nuevo documento de texto y lo nombras 16f876a.inc
LIST
; P16F876A.INC Standard Header File, Version 1.00 Microchip Technology, Inc.
NOLIST
; This header file defines configurations, registers, and other useful bits of
; information for the PIC16F877A microcontroller. These names are taken to match
; the data sheets as closely as possible.
; Note that the processor must be selected before this file is
; included. The processor may be selected the following ways:
; 1. Command line switch:
; C:\ MPASM MYFILE.ASM /PIC16F876A
; 2. LIST directive in the source file
; LIST P=PIC16F876A
; 3. Processor Type entry in the MPASM full-screen interface
; Revision History
;Rev: Date: Reason:
;1.02 05/28/02 Corrected values for _CP_ALL and _CP_OFF in Configuration Bits section.
;1.01 10/03/01 Added the PIR2 bit CMIF and the PIE2 bit CMIE
;1.00 04/19/01 Initial Release (BD - generated from PIC16F877.inc)
; Verify Processor
IFNDEF __16F876A
MESSG "Processor-header file mismatch. Verify selected processor."
ENDIF
; Register Definitions
W EQU H'0000'
F EQU H'0001'
;----- Register Files------------------------------------------------------
INDF EQU H'0000'
TMR0 EQU H'0001'
PCL EQU H'0002'
STATUS EQU H'0003'
FSR EQU H'0004'
PORTA EQU H'0005'
PORTB EQU H'0006'
PORTC EQU H'0007'
PCLATH EQU H'000A'
INTCON EQU H'000B'
PIR1 EQU H'000C'
PIR2 EQU H'000D'
TMR1L EQU H'000E'
TMR1H EQU H'000F'
T1CON EQU H'0010'
TMR2 EQU H'0011'
T2CON EQU H'0012'
SSPBUF EQU H'0013'
SSPCON EQU H'0014'
CCPR1L EQU H'0015'
CCPR1H EQU H'0016'
CCP1CON EQU H'0017'
RCSTA EQU H'0018'
TXREG EQU H'0019'
RCREG EQU H'001A'
CCPR2L EQU H'001B'
CCPR2H EQU H'001C'
CCP2CON EQU H'001D'
ADRESH EQU H'001E'
ADCON0 EQU H'001F'
OPTION_REG EQU H'0081'
TRISA EQU H'0085'
TRISB EQU H'0086'
TRISC EQU H'0087'
PIE1 EQU H'008C'
PIE2 EQU H'008D'
PCON EQU H'008E'
SSPCON2 EQU H'0091'
PR2 EQU H'0092'
SSPADD EQU H'0093'
SSPSTAT EQU H'0094'
TXSTA EQU H'0098'
SPBRG EQU H'0099'
CMCON EQU H'009C'
CVRCON EQU H'009D'
ADRESL EQU H'009E'
ADCON1 EQU H'009F'
EEDATA EQU H'010C'
EEADR EQU H'010D'
EEDATH EQU H'010E'
EEADRH EQU H'010F'
EECON1 EQU H'018C'
EECON2 EQU H'018D'
;----- STATUS Bits --------------------------------------------------------
IRP EQU H'0007'
RP1 EQU H'0006'
RP0 EQU H'0005'
NOT_TO EQU H'0004'
NOT_PD EQU H'0003'
Z EQU H'0002'
DC EQU H'0001'
C EQU H'0000'
;----- INTCON Bits --------------------------------------------------------
GIE EQU H'0007'
PEIE EQU H'0006'
T0IE EQU H'0005'
INTE EQU H'0004'
RBIE EQU H'0003'
T0IF EQU H'0002'
INTF EQU H'0001'
RBIF EQU H'0000'
;----- PIR1 Bits ----------------------------------------------------------
ADIF EQU H'0006'
RCIF EQU H'0005'
TXIF EQU H'0004'
SSPIF EQU H'0003'
CCP1IF EQU H'0002'
TMR2IF EQU H'0001'
TMR1IF EQU H'0000'
;----- PIR2 Bits ----------------------------------------------------------
CMIF EQU H'0006'
EEIF EQU H'0004'
BCLIF EQU H'0003'
CCP2IF EQU H'0000'
;----- T1CON Bits ---------------------------------------------------------
T1CKPS1 EQU H'0005'
T1CKPS0 EQU H'0004'
T1OSCEN EQU H'0003'
NOT_T1SYNC EQU H'0002'
T1INSYNC EQU H'0002' ; Backward compatibility only
T1SYNC EQU H'0002'
TMR1CS EQU H'0001'
TMR1ON EQU H'0000'
;----- T2CON Bits ---------------------------------------------------------
TOUTPS3 EQU H'0006'
TOUTPS2 EQU H'0005'
TOUTPS1 EQU H'0004'
TOUTPS0 EQU H'0003'
TMR2ON EQU H'0002'
T2CKPS1 EQU H'0001'
T2CKPS0 EQU H'0000'
;----- SSPCON Bits --------------------------------------------------------
WCOL EQU H'0007'
SSPOV EQU H'0006'
SSPEN EQU H'0005'
CKP EQU H'0004'
SSPM3 EQU H'0003'
SSPM2 EQU H'0002'
SSPM1 EQU H'0001'
SSPM0 EQU H'0000'
;----- CCP1CON Bits -------------------------------------------------------
CCP1X EQU H'0005'
CCP1Y EQU H'0004'
CCP1M3 EQU H'0003'
CCP1M2 EQU H'0002'
CCP1M1 EQU H'0001'
CCP1M0 EQU H'0000'
;----- RCSTA Bits ---------------------------------------------------------
SPEN EQU H'0007'
RX9 EQU H'0006'
RC9 EQU H'0006' ; Backward compatibility only
NOT_RC8 EQU H'0006' ; Backward compatibility only
RC8_9 EQU H'0006' ; Backward compatibility only
SREN EQU H'0005'
CREN EQU H'0004'
ADDEN EQU H'0003'
FERR EQU H'0002'
OERR EQU H'0001'
RX9D EQU H'0000'
RCD8 EQU H'0000' ; Backward compatibility only
;----- CCP2CON Bits -------------------------------------------------------
CCP2X EQU H'0005'
CCP2Y EQU H'0004'
CCP2M3 EQU H'0003'
CCP2M2 EQU H'0002'
CCP2M1 EQU H'0001'
CCP2M0 EQU H'0000'
;----- ADCON0 Bits --------------------------------------------------------
ADCS1 EQU H'0007'
ADCS0 EQU H'0006'
CHS2 EQU H'0005'
CHS1 EQU H'0004'
CHS0 EQU H'0003'
GO EQU H'0002'
NOT_DONE EQU H'0002'
GO_DONE EQU H'0002'
ADON EQU H'0000'
;----- OPTION_REG Bits -----------------------------------------------------
NOT_RBPU EQU H'0007'
INTEDG EQU H'0006'
T0CS EQU H'0005'
T0SE EQU H'0004'
PSA EQU H'0003'
PS2 EQU H'0002'
PS1 EQU H'0001'
PS0 EQU H'0000'
;----- PIE1 Bits ----------------------------------------------------------
ADIE EQU H'0006'
RCIE EQU H'0005'
TXIE EQU H'0004'
SSPIE EQU H'0003'
CCP1IE EQU H'0002'
TMR2IE EQU H'0001'
TMR1IE EQU H'0000'
;----- PIE2 Bits ----------------------------------------------------------
CMIE EQU H'0006'
EEIE EQU H'0004'
BCLIE EQU H'0003'
CCP2IE EQU H'0000'
;----- PCON Bits ----------------------------------------------------------
NOT_POR EQU H'0001'
NOT_BO EQU H'0000'
NOT_BOR EQU H'0000'
;----- SSPCON2 Bits --------------------------------------------------------
GCEN EQU H'0007'
ACKSTAT EQU H'0006'
ACKDT EQU H'0005'
ACKEN EQU H'0004'
RCEN EQU H'0003'
PEN EQU H'0002'
RSEN EQU H'0001'
SEN EQU H'0000'
;----- SSPSTAT Bits -------------------------------------------------------
SMP EQU H'0007'
CKE EQU H'0006'
D EQU H'0005'
I2C_DATA EQU H'0005'
NOT_A EQU H'0005'
NOT_ADDRESS EQU H'0005'
D_A EQU H'0005'
DATA_ADDRESS EQU H'0005'
P EQU H'0004'
I2C_STOP EQU H'0004'
S EQU H'0003'
I2C_START EQU H'0003'
R EQU H'0002'
I2C_READ EQU H'0002'
NOT_W EQU H'0002'
NOT_WRITE EQU H'0002'
R_W EQU H'0002'
READ_WRITE EQU H'0002'
UA EQU H'0001'
BF EQU H'0000'
;----- TXSTA Bits ---------------------------------------------------------
CSRC EQU H'0007'
TX9 EQU H'0006'
NOT_TX8 EQU H'0006' ; Backward compatibility only
TX8_9 EQU H'0006' ; Backward compatibility only
TXEN EQU H'0005'
SYNC EQU H'0004'
BRGH EQU H'0002'
TRMT EQU H'0001'
TX9D EQU H'0000'
TXD8 EQU H'0000' ; Backward compatibility only
;----- CMCON Bits ---------------------------------------------------------
C2OUT EQU H'0007'
C1OUT EQU H'0006'
C2INV EQU H'0005'
C1INV EQU H'0004'
CIS EQU H'0003'
CM2 EQU H'0002'
CM1 EQU H'0001'
CM0 EQU H'0000'
;----- CVRCON Bits --------------------------------------------------------
CVREN EQU H'0007'
CVROE EQU H'0006'
CVRR EQU H'0005'
CVR3 EQU H'0003'
CVR2 EQU H'0002'
CVR1 EQU H'0001'
CVR0 EQU H'0000'
;----- ADCON1 Bits --------------------------------------------------------
ADFM EQU H'0007'
PCFG3 EQU H'0003'
PCFG2 EQU H'0002'
PCFG1 EQU H'0001'
PCFG0 EQU H'0000'
;----- EECON1 Bits --------------------------------------------------------
EEPGD EQU H'0007'
WRERR EQU H'0003'
WREN EQU H'0002'
WR EQU H'0001'
RD EQU H'0000'
; RAM Definition
__MAXRAM H'1FF'
__BADRAM H'8F'-H'90', H'95'-H'97', H'9A'-H'9B'
__BADRAM H'105', H'107'-H'109'
__BADRAM H'185', H'187'-H'189', H'18E'-H'18F'
; Configuration Bits
_CP_ALL EQU H'1FFF'
_CP_OFF EQU H'3FFF'
_DEBUG_OFF EQU H'3FFF'
_DEBUG_ON EQU H'37FF'
_WRT_OFF EQU H'3FFF' ; No prog memmory write protection
_WRT_256 EQU H'3DFF' ; First 256 prog memmory write protected
_WRT_1FOURTH EQU H'3BFF' ; First quarter prog memmory write protected
_WRT_HALF EQU H'39FF' ; First half memmory write protected
_CPD_OFF EQU H'3FFF'
_CPD_ON EQU H'3EFF'
_LVP_ON EQU H'3FFF'
_LVP_OFF EQU H'3F7F'
_BODEN_ON EQU H'3FFF'
_BODEN_OFF EQU H'3FBF'
_PWRTE_OFF EQU H'3FFF'
_PWRTE_ON EQU H'3FF7'
_WDT_ON EQU H'3FFF'
_WDT_OFF EQU H'3FFB'
_RC_OSC EQU H'3FFF'
_HS_OSC EQU H'3FFE'
_XT_OSC EQU H'3FFD'
_LP_OSC EQU H'3FFC'
LIST
